Low resolutions with 3070Ti not possible? It was working fine with 2070
11-20-2022, 10:43 PM
RE: Low resolutions with 3070Ti not possible? It was working fine with 2070
Finally i've found a workaround. I use 2 graphic cards. They have to use the same driver, so for a RTX 2000 or RTX 3000 graphic card, the second one should be at least a GTX 1030.
My CRT is plugged into the GTX 1030 wich has a DAC that do low res from DP port ( 320x224 works great ) and the rendering is done from the 3070, it just passthrough the signal to the 1030 DAC Can be interesting for future graphic cards generations and CRT gaming. |
