NVIDIA Pixel Clock Patcher
09-07-2012, 09:07 PM
(Last edited: 05-06-2023, 09:11 PM by ToastyX)
NVIDIA Pixel Clock Patcher modifies the NVIDIA video driver to allow higher resolutions and refresh rates by removing the 165 MHz pixel clock limit for single-link DVI and HDMI, the 330 MHz limit for dual-link DVI, and the 400 MHz limit for SLI and 400/500-series GPUs.
Download: nvlddmkm-patcher-1.4.16.zip - Source: nvlddmkm-patcher-1.4.16-src.zip A message from ToastyX: Requirements:
To restore the unpatched driver, run the patcher again and click "Yes" to restore from backup. Unpatching is not required before upgrading drivers. Simply run the patcher again after installing the new driver. Options: You can rename the .exe file to change certain options:
09-08-2012, 04:44 PM
RE: NVIDIA Pixel Clock Patcher
You're a Sexy Bitch and I love you. But you already knew that.
09-08-2012, 08:34 PM
thanks you soo much!!!! donated to your cause. not much, but better than nothing.
09-08-2012, 09:59 PM
do i need to always stay in TEST MODE? I went back to normal mode and the NVIDIA drivers didnt want to load. i did sign the file you mentioned.
thanks again! |
09-08-2012, 11:06 PM
yes toastyx i donate to you but Hyper made me do it haha J/K
With all the hard work you do for every one like i said what the Hell is $5.00 donate and im glad to do it. |
09-08-2012, 11:33 PM
Thanks for the support. I really appreciate it.
(09-08-2012 09:59 PM)twincam23 Wrote: do i need to always stay in TEST MODE? I went back to normal mode and the NVIDIA drivers didnt want to load. i did sign the file you mentioned.Yes, you have to stay in test mode to use a self-signed driver, but that doesn't affect anything. You can use DSEO to remove the "Test Mode" watermark from the desktop. |
09-09-2012, 12:44 AM
TY Toasty!
Awesome work ![]() Im donating too, but need to wait until Monday. TY! |
09-09-2012, 02:51 AM
Hey ToastyX, amazing work there. Got a question for ya... is this patcher going to work with future drivers or do we gotta check back for each version? unless they go out of their way to change the code in the drivers that is
09-09-2012, 04:04 AM
It will work with future versions if the code doesn't change.
09-10-2012, 12:14 AM
Thank you very much! I donated because I appreciate your time and effort. It helped me make my decision to go with nvidia. I'll donate again when I get my card and monitor in a couple of weeks ,because I think 5 dollars is getting off cheap. Thank you again kind Sir!
User(s) browsing this thread: 41 Guest(s)
![[Image: patreon.png]](https://www.monitortests.com/images/patreon.png)
