144 Hz monitor and capture card mirrored
02-26-2015, 07:24 PM
(Last edited: 02-26-2015, 07:40 PM by DarkHole)
I want to duplicate my 144 Hz monitor to my capture card (LGP Lite). Whenever I try to duplicate the displays my main monitor goes from 144 Hz down to 60 Hz.
I know Nvidia supports mirrored monitors with different refresh rates, but I am using AMD and I have found that Lightboost forces my main monitor to 120 Hz even if it is mirrored with the capture card. Lightboost is not a solution for me though, because my eyes feels so annoyed when it is enabled. I hate it. So is there any way to force my main monitor to 144 Hz? |
02-28-2015, 04:47 PM
RE: 144 Hz monitor and capture card mirrored
(02-26-2015 07:24 PM)DarkHole Wrote: I know Nvidia supports mirrored monitors with different refresh rates, but I am using AMD and I have found that Lightboost forces my main monitor to 120 Hz even if it is mirrored with the capture card. Lightboost is not a solution for me though, because my eyes feels so annoyed when it is enabled. I hate it.LightBoost wouldn't force 120 Hz. Did you use Strobelight? You probably forced 120 Hz by not installing lower refresh rates. You can do the same with CRU. (02-26-2015 07:24 PM)DarkHole Wrote: So is there any way to force my main monitor to 144 Hz?Use CRU to add 1920x1080 @ 144 Hz as the first detailed resolution (use "LCD reduced"), and remove all the other resolutions. Make sure to disable the extension block or use a custom one because the default one probably has other refresh rates in there. |
