Default Settings for my monitor
07-28-2020, 06:12 AM
I was messing around in cru to get less input delay using stretched res and now I don't have the option for 240hz in my nvidia control panel. I can create a custom res but I just want to go back to default settings. The problem I'm having is that I don't have a default button.
07-28-2020, 12:02 PM
RE: Default Settings for my monitor
CRU provides reset-all.exe which resets everything to default.
07-28-2020, 05:32 PM
(07-28-2020 12:02 PM)ToastyX Wrote:  CRU provides reset-all.exe which resets everything to default.
I just used the reset all.exe and now under my PC resolutions in control panel, I only have the options for 144hz and 120hz
07-28-2020, 10:56 PM
Then it's not a CRU problem. What model is the monitor? Are you using DisplayPort?
07-29-2020, 03:57 AM
(07-28-2020 10:56 PM)ToastyX Wrote:  Then it's not a CRU problem. What model is the monitor? Are you using DisplayPort?
I have the new alienware 25 inch. and im using display port. Never had this problem before I used cru
07-29-2020, 04:40 PM
If 240 Hz is not available, that means the DisplayPort connection is not running at the correct speed. This can happen with a bad cable or a firmware bug in the monitor. Try unplugging the monitor's power for a minute to reset it.
If that doesn't help, try reinstalling the graphics driver after using DDU: https://www.wagnardsoft.com/display-driv...aller-ddu-
