Help with Monitor Ghosting
07-09-2014, 02:57 PM
Hi
I have an AMD R9 290x graphics card with 3 (VGA only) monitors: DVI-D -----> Startech Active Adapter ------> VGA DisplayPort -----> Startech Active Adapter ------> VGA DVI-D -----> Startech Active Adapter ------> VGA The monitors using the DVI-D connections are not as sharp as the DisplayPort. There's a bit of ghostng... Is there anything I can/should do? Thanks to anyone that responds :-) |
07-10-2014, 07:29 PM
RE: Help with Monitor Ghosting
That sounds like a quality issue with the DVI adapters. VGA is susceptible to interference. You might have better luck with a different adapter or with different cables.
