03-05-2025, 06:16 PM
Post: #8881
(03-04-2025 03:03 AM)juanme555 Wrote: Okay now, based lord Toasty , i have now bought a GTX 1080 Ti and im using the same HDMI to VGA adapter i was using with intel igpu that was capable of doing , but now on nvidia drivers im on drivers 572.60 and interlaced resolutions are not supported at all! when i try to create one on the control panel it just says "this resolution isnt compatible with your display" or smth like that.Use CRU to add the resolutions, not the NVIDIA control panel. |
03-06-2025, 12:57 AM
Post: #8882
(03-05-2025 06:16 PM)ToastyX Wrote:(03-04-2025 03:03 AM)juanme555 Wrote: Okay now, based lord Toasty , i have now bought a GTX 1080 Ti and im using the same HDMI to VGA adapter i was using with intel igpu that was capable of doing , but now on nvidia drivers im on drivers 572.60 and interlaced resolutions are not supported at all! when i try to create one on the control panel it just says "this resolution isnt compatible with your display" or smth like that.Use CRU to add the resolutions, not the NVIDIA control panel. Just tried adding them through CRU in detailed resolutions, they don't show up at all in windows node list. |
03-06-2025, 02:07 AM
Post: #8883
(03-05-2025 06:16 PM)ToastyX Wrote:(03-05-2025 03:19 AM)p14t1pu516 Wrote: Hello Toastyx, i hope you are well.That error message is not coming from reset-all.exe. What is the exact error message? You shouldn't need to reformat. The exported .exe file can also uninstall the EDID override. Hello toastyx, thank you for your prompt response. I can't access any files in the cru folder in secure mode. the message is: "the system cannot access the file", nothing more than that. Device Manager says that the best drivers for the "intel uhd graphics 630" device are now updated. On the Intel website I can't find drivers for the Intel UHD 630, and the Intel Driver Assistant says: "There are no compatible driver or software updates available for your system." I would like to know if there is any other specific way to ensure that when starting the PC, the HDMI 1360x768 resolution is transformed into DVI 1360x768, as happened before. thank you very much |
03-06-2025, 01:25 PM
Post: #8884
(03-06-2025 02:07 AM)p14t1pu516 Wrote: Hello toastyx, thank you for your prompt response.What is secure mode? It's not normal to not be able to access the files. Something is wrong. You are still using the same computer. There is no reason it shouldn't work like before. This is the latest driver for your GPU: https://www.intel.com/content/www/us/en/...ndows.html |
Post: #8885
(03-06-2025 12:57 AM)juanme555 Wrote: Just tried adding them through CRU in detailed resolutions, they don't show up at all in windows node list.Did you add the progressive version? I told you this before: (09-19-2024 09:37 PM)ToastyX Wrote: I have a GTX 1070. I just tested again with the latest driver, 561.09. Interlaced works with HDMI as long as the progressive version also exists. I was able to add 1920x1200i @ 90 Hz as long as I also add 1920x1200p @ 90 Hz (can be standard or detailed resolution). |
03-06-2025, 06:11 PM
(Last edited: 03-06-2025, 06:15 PM by p14t1pu516)
Post: #8886
(03-06-2025 01:25 PM)ToastyX Wrote:(03-06-2025 02:07 AM)p14t1pu516 Wrote: Hello toastyx, thank you for your prompt response.What is secure mode? It's not normal to not be able to access the files. Something is wrong. You are still using the same computer. There is no reason it shouldn't work like before. This is the latest driver for your GPU: https://www.intel.com/content/www/us/en/...ndows.html Sorry for my English, I meant safe mode. Yes, it's exactly the same pc, only I installed windows 10 on a hdd (I had an ssd before). The hard drive is fine, I formatted it in ntfs. I really appreciate you giving me the link to the drivers. Now I can use reset all in safe mode, but unfortunately the original problem was not solved. When I use the exe file, install edid and use restart64, it works, it goes to DVI. The problem is when I restart the pc. It keeps thinking about the start and never starts. If I don't use restart64 and restart pc, the same thing happens. I've never touched the BIOS, but could there be something there? When everything was working fine (with the sdd), at the beginning it changed from hdmi to dvi, now it keeps thinking about the gigabyte logo. I hope you can help me, thank you very much. |
03-06-2025, 06:23 PM
Post: #8887
(03-06-2025 01:25 PM)ToastyX Wrote:(03-06-2025 12:57 AM)juanme555 Wrote: Just tried adding them through CRU in detailed resolutions, they don't show up at all in windows node list.Did you add the progressive version? I told you this before: will try, is it okay if the progressive resolution wouldnt run at all? cuz i wanna use 1920x1200i 144hz , but 1920x1200p would DEFINITELY no signal on my crt at 144hz cuz it only has 96kHz , anyways i'll try and get back to you. |
03-06-2025, 06:42 PM
Post: #8888
(03-06-2025 06:23 PM)juanme555 Wrote: will try, is it okay if the progressive resolution wouldnt run at all? cuz i wanna use 1920x1200i 144hz , but 1920x1200p would DEFINITELY no signal on my crt at 144hz cuz it only has 96kHz , anyways i'll try and get back to you.Yes, you don't need to use the progressive resolution. |
03-06-2025, 06:55 PM
Post: #8889
(03-06-2025 06:11 PM)p14t1pu516 Wrote: Sorry for my English, I meant safe mode. Yes, it's exactly the same pc, only I installed windows 10 on a hdd (I had an ssd before). The hard drive is fine, I formatted it in ntfs.That really sounds like a driver issue. Can you show me what you have in CRU? Maybe the newer drivers have a bug and you were using an older driver. The driver link has several versions that you can try. I would try the oldest first to see if that works. Only issue is Windows might automatically upgrade the driver later. There is also this driver which is older and works with your GPU: https://www.intel.com/content/www/us/en/...ndows.html |
03-06-2025, 08:43 PM
Post: #8890
(03-06-2025 06:42 PM)ToastyX Wrote:(03-06-2025 06:23 PM)juanme555 Wrote: will try, is it okay if the progressive resolution wouldnt run at all? cuz i wanna use 1920x1200i 144hz , but 1920x1200p would DEFINITELY no signal on my crt at 144hz cuz it only has 96kHz , anyways i'll try and get back to you.Yes, you don't need to use the progressive resolution. yeah, it defintely didn't work on the latest drivers, i guess i'll have to go back to the 2023 drivers and pray that it supports the new games D: |
User(s) browsing this thread: 79 Guest(s)
