					Low Resolutions on VG279QM Problem
					07-12-2021, 07:04 AM
(Last edited: 07-12-2021, 07:05 AM by Alias_Uruz)
				 Post: #1 | |||
					Hi there, I was aways a fan of the CRU, thanks for that amazing tool, ToastyX ♥ I'm having a problem with trying lower resolutions, anything higher than 720p and lower than 1080p is REALLY glitchy. Sure, I could use GPU scaling, but the screen gets blurrier. I tried using Exact Reduced and every other option. Is there anything new I can try? Again, thanks for the programs and the support you give on the forum, ToastyX. | |||
					07-14-2021, 01:16 PM
				 Post: #2 | |||
| RE: Low Resolutions on VG279QM Problem
					Try setting the horizontal/vertical totals to the same as the 1080p resolution.
					07-14-2021, 05:18 PM
				 Post: #3 | |||
| RE: Low Resolutions on VG279QM Problem | |||
					07-17-2021, 04:02 PM
				 Post: #4 | |||
					Probably a limitation of the monitor. Might only happen with G-SYNC enabled.
					07-18-2021, 07:40 AM
				 Post: #5 | |||
