R9 290x Problem
12-03-2014, 03:07 PM
R9 290x Problem
Ciao a tutti.
Ho un problema un po strano: Ho un pc con scheda video amd r9 290x collegata ad una tv e funziona senza problemi sia in dvi che in hdmi. Ora ho comprato un monitor 144hz, sul monitor ricevo il messaggio nessun segnale, e non viene proprio rilevato dal pc. ho provato il monitor sulla video integrata, su una gtx260 ed anche sulla xbox 360 e funziona. cosa potrebbe mai essere? Inoltre il pc non mi rileva alcun altro monitor al di fuori di quello che uso principalmente. Grazie Hello everyone. I have a problem a bit strange: I have a PC with a video card amd r9 290x connected to a TV and it works without any problem in that dvi hdmi. Now I bought a 144hz monitor, the monitor I get the message no signal, and is not detected by the own PC. I tried the monitor on integrated video, on a GTX260 and also on Xbox 360 and it works. What could it be? In addition, the PC did not detect any other monitor outside what I use mainly. thanks |
12-04-2014, 12:34 PM
RE: R9 290x Problem
Make sure the monitor is connected to a dual-link DVI port with a dual-link DVI cable. Older AMD cards only have one dual-link DVI port, but R9 290X cards should have two. Even if the monitor is connected to a single-link DVI port, it should at least work at 60 Hz, so I don't know what's going on.
