stretched res for CS with LG 32gs95ue and RTX 5090
02-01-2025, 06:36 PM
hello,
I have an LG 32gs95ue connected with DP 1.4 to new RTX 5090.
My monitor supports 4k@240hz and 1080p@480hz (dual mode) with DSC on DP 1.4 and HDMI 2.1
I have a new 5090 and now with the recent drivers I cant use GPU scaling anymore to stretch 1440x1080 to 1920x1080 @480hz. I only have display scaling and my 4:3 resolutions are limited to 1024x768 or 800x600.
Before, with my 4090 I was able to use GPU scaling and had zero issue with it. I could play on 1440x1080 stretched @480hz.
Is there a workaround or is the 5090 more limited than the 4090 with DP 1.4 or HDMI ? Is this a driver issue (tried to fresh install and only connect this monitor without success) ?
Thank you
02-02-2025, 03:34 PM
RE: stretched res for CS with LG 32gs95ue and RTX 5090
Is 1440x1080 listed in SRE? What about adding it to CRU and using display scaling?
02-02-2025, 04:24 PM
(02-02-2025 03:34 PM)ToastyX Wrote:  Is 1440x1080 listed in SRE? What about adding it to CRU and using display scaling?
Yes it is listed on SRE.
I didn't try with CRU but I think my monitor dont support them with display scaling, only the resolution already there.
I can create custom res in Nvidia panel but when I create a 1440x1080 resolution it says than my monitor dont support it when I hit "test", same with 1280x960.
GPU scaling was the best and only ways to do it and now it's gone.
02-02-2025, 06:12 PM (Last edited: 02-02-2025, 06:55 PM by calci)
And DLDSR is possible with my 5090 and my monitor with DSC without an issue. I thought DLDSR was not possible with DSC, I dont understand.
I was able to add 1440x1080 to display scaling with CRU ! Thank you toastyX !
02-02-2025, 07:13 PM (Last edited: 02-02-2025, 07:14 PM by calci)
And in my monitor information with 1440x1080 and display scaling it says 1920x1080. So is the GPU or the display scaling the resolution to full screen ? I have the impression that the GPU is doing it even if I cant select GPU scaling in the control panel, I'm confused. But I can play with 1440x1080 @480hz stretched now so I'm happy !
02-03-2025, 05:38 AM
(02-02-2025 06:12 PM)calci Wrote:  And DLDSR is possible with my 5090 and my monitor with DSC without an issue. I thought DLDSR was not possible with DSC, I dont understand.
It's possible if it's within the single head limit. The 5090 must have a higher limit.
(02-02-2025 07:13 PM)calci Wrote:  And in my monitor information with 1440x1080 and display scaling it says 1920x1080. So is the GPU or the display scaling the resolution to full screen ? I have the impression that the GPU is doing it even if I cant select GPU scaling in the control panel, I'm confused. But I can play with 1440x1080 @480hz stretched now so I'm happy !
Any resolution @ refresh rate combination listed in CRU is supposed to be display scaled, but if you switch to a lower resolution in the Windows display settings, it will be scaled to the current active resolution if the refresh rate is the same, so if you are in 1920x1080 @ 480 Hz mode and switch to 1440x1080, it will be scaled by the GPU. It shouldn't do that if you change the resolution in the NVIDIA control panel, or if you go to advanced display settings > display adapter properties > list all modes. If it does, it's some NVIDIA-specific scaling issue. I don't know if there's a way to control which method gets used in games.
06-05-2025, 04:23 AM
(02-01-2025 06:36 PM)calci Wrote:  hello,
Thank you
hello i have been having this same exact issue i have the same exact monitor and just purchased a 5090 and cannot create a 1440x1080 resolution. Would you be able to record and upload a tutorial to youtube of how you did it? Thank you!
06-05-2025, 01:08 PM
(06-05-2025 04:23 AM)nin7h Wrote:  hello i have been having this same exact issue i have the same exact monitor and just purchased a 5090 and cannot create a 1440x1080 resolution. Would you be able to record and upload a tutorial to youtube of how you did it? Thank you!
Why can't you create 1440x1080? Explain what the problem is.
06-18-2025, 06:52 AM
hello, i have the exact same setup with the same issue, when i tried adding 1440x1080 480hz on CRU, the dual mode stopped working, calci, can you show me your cru configuration, because when i switch back to 4k mode after adding 1440x1080 480hz, the monitor isnt 4k anymore
10-15-2025, 10:53 AM
Hello, how can I add a 1440x1080@480hz resolution via CRU? In any of the automatic timings modes I can't go anywhere near 400hz at that resolution, the refresh rate number becomes red and doesn't let me apply.
Same thing with AMD custom resolution utility, it will let me create a "custom" 1920x1080 480hz res, but when trying 1440x1080 it will say that these custom resolution settings are not compatible with this display and refuse to let me save or try them.
Then if I go to CS2 launch options and try adding -w 1440 -h 1080, when the game launches I just get a black screen. The steam overlay works but the game just displays pure black. This is a bit frustrating. Especially with the added 600nit HDR limit mess, making me regret getting this monitor instead of the 480hz 1440p LG one for a similar price...
