Custom Resolution Utility (CRU) Work in Progress
12-31-2025, 11:30 PM
(Last edited: 12-31-2025, 11:45 PM by ToastyX)
It has been a while since CRU has had a major update. I've been working on rewriting CRU from scratch, but it's taking longer than I'd like, so I thought I'd release a work in progress to give advanced users something to play with. Some features have not been reimplemented yet, and it has not been fully tested. This will not be the UI for CRU 2.0. CRU 2.0 will have an easier consolidated mode with a new layout and an advanced mode. This is more like the advanced mode but with the old layout.
Download: cru-test-2026-01.zip Important differences:
04-14-2026, 02:16 AM
(Last edited: 04-14-2026, 02:29 AM by intimki)
RE: Custom Resolution Utility (CRU) Work in Progress
CRU only works if IOMMU is enabled in the BIOS. Otherwise, Windows simply freezes during the driver initialization phase on the boot screen. How can I fix this? I don't want to have to enable IOMMU all the time
NVIDIA RTX 3080, Driver 596.02 |
04-14-2026, 02:54 AM
(04-14-2026 02:16 AM)intimki Wrote: CRU only works if IOMMU is enabled in the BIOS. Otherwise, Windows simply freezes during the driver initialization phase on the boot screen. How can I fix this? I don't want to have to enable IOMMU all the timeDo you have multiple displays connected? NVIDIA's driver has a bug that can cause Windows to hang during boot when an EDID override is present with multiple displays connected and G-SYNC enabled. There is a workaround using scripts: https://www.monitortests.com/forum/Threa...wn-scripts |
04-14-2026, 04:27 AM
(04-14-2026 02:54 AM)ToastyX Wrote:I actually have two monitors, but I tested various methods with just one connected. It makes absolutely no difference.(04-14-2026 02:16 AM)intimki Wrote: CRU only works if IOMMU is enabled in the BIOS. Otherwise, Windows simply freezes during the driver initialization phase on the boot screen. How can I fix this? I don't want to have to enable IOMMU all the timeDo you have multiple displays connected? NVIDIA's driver has a bug that can cause Windows to hang during boot when an EDID override is present with multiple displays connected and G-SYNC enabled. There is a workaround using scripts: https://www.monitortests.com/forum/Threa...wn-scripts In addition, the script, as a general solution, is just a one-time fix. The reason is: reboots, accidental power outages, etc., when the EDID reset won’t have time to take effect. In any case, resetting the EDID won’t help on the next boot unless you apply it in advance every time before shutting down |
04-15-2026, 06:54 PM
(04-14-2026 04:27 AM)intimki Wrote: I actually have two monitors, but I tested various methods with just one connected. It makes absolutely no difference.This can only be an NVIDIA driver bug. The IOMMU must be preventing the driver from hanging. This must be a new bug because I'm not aware of this happening with a single monitor connected. The workaround includes making a shutdown script, but you can actually reset the EDID immediately after restarting the driver instead. The EDID override will still be in effect as long as the driver doesn't restart. |
07-19-2026, 09:36 PM
(Last edited: 07-19-2026, 09:37 PM by winterkid09)
Hi Toasty,
I believe that cru-test-2026-01 is mis-handling color-depth support for YCbCr 4:2:2 & YCbCr 4:2:0 encoding, it seems the Display Interface Features block within DisplayID 2.0 extension doesn't actually support 6bpc these two, so bit 0 should flag support for 8bpc instead of 6bpc By the way, this version of CRU is super impressive! Seriously, nice work ~~ |
07-20-2026, 04:59 PM
(07-19-2026 09:36 PM)winterkid09 Wrote: Hi Toasty,I just checked and you're right. I haven't been working on it lately, but I'll make sure that's fixed in the next release. |
