05-07-2021, 10:22 PM (Last edited: 05-10-2021, 07:45 AM by hoffr)
Post: #5831
Issue: Monitor wake/Sleep resume - Dim screen, 'hardware removed, then inserted' chim
Issue: Monitor wake/Sleep resume - Dim screen, 'hardware removed, then inserted' chimes
If I have any custom Detailed Resolutions whatsoever even if I'm not actively using one, on resume from sleep (more specifically it's the wake of the powered-off monitor, have tested that with PC on), the Windows 10 'hardware inserted' chime will sometimes play, and sometimes 'hardware removed' will couple that. Every time though, I will have a dim screen. I suspect it's the driver's presentation of colors that's dim and not the backlight, since my cursor is bright like normal.
Pressing CTRL+SHIFT+WIN+B resets something in the driver and then it's normal. Dim screen happens about 9 out of 10 times, otherwise may still make hardware chimes. USB Selective Suspend in power plan options doesn't solve the issue as some online sources may present
I've read a reply here about this exact issue: My monitor does not support HDR, nor are there any HDR-related extension blocks used. It really doesn't seem to matter what the content of the custom detailed resolution is, just that one needs to be present. I made one identical to the default & restart.exe'd and there's still the issue, even though I'm not actively using that detailed resolution entry.
Here's my current config anyway:
[Image: lLVceYt.png]
Thank you ToastyX for all your hard work managing this project's support line, really seems like a lot to do. Could I recommend using Github to track issues? It's much more graceful for both parties involved, reviewer and submitter (plus users wouldn't have to create new forum accounts just to report a bug).
Environment:
- CRU 1.5.1
- Win10 Pro 20H2
- RX 570 stock
- Radeon software version 21.5.1 (dates at least back to versions 4 months old, havent tried others / DDU doesn't solve issue)
- I had f.lux installed but uninstalled/restarted pc to test this, it's not the culprit
05-11-2021, 09:44 PM
Post: #5832
Update to previous post about the dim screen issue: It doesn't seem to have to do with restart.exe itself, since creating a new detailed resolution in CRU but then using AMD's driver restart function rather than restart.exe (by creating/deleting some random profile, forcing display restart) still causes the issue.
Creating a profile identical to what causes an issue in CRU, but instead within in AMD's custom res menu does not cause the issue. I can do anything I want in AMD's menus and I don't get a dim screen. Sometimes it'll tell me a custom res is not compatible with my monitor though, but this wasn't the case for any of the ones I had issues with in CRU.
I've also figured out that the Windows insert/remove sounds are likely just a quirk of my monitor, probably +AMD driver or some Windows thing. Not CRU related.
05-12-2021, 09:11 PM
Post: #5833
Hi, I have a question that I can't seem to find any answers to. I'm using a Sony 4K tv and trying to add 2560x1440 @ 120hz under tv resolutions, but I can't seem to figure out how. Is it not possible? I'm doing this to try and use YCBCR instead of RGB, because 1440p @ 120hz will only do RGB when added normally in CRU. Am I attempting to do something that simply can't be done, or am I doing something incorrectly? Thank you.
05-13-2021, 01:10 AM
Post: #5834
(05-07-2021 10:22 PM)hoffr Wrote:  Issue: Monitor wake/Sleep resume - Dim screen, 'hardware removed, then inserted' chimes
This is an AMD driver bug that I can't do anything about. Ctrl+Shift+Win+B is the easiest workaround. I don't know what conditions trigger the bug because I don't have any hardware that reproduces it. It's not an issue with the EDID override itself, but something AMD's driver is doing when an EDID override is present.
(05-07-2021 10:22 PM)hoffr Wrote:  Thank you ToastyX for all your hard work managing this project's support line, really seems like a lot to do. Could I recommend using Github to track issues? It's much more graceful for both parties involved, reviewer and submitter (plus users wouldn't have to create new forum accounts just to report a bug).
There haven't been many issues with CRU itself. It's been well-tested and actual bugs are rarely reported. The vast majority of issues people encounter are either driver bugs or hardware/driver limitations.
05-13-2021, 01:12 AM
Post: #5835
(05-12-2021 09:11 PM)TheAshmanCometh Wrote:  Hi, I have a question that I can't seem to find any answers to. I'm using a Sony 4K tv and trying to add 2560x1440 @ 120hz under tv resolutions, but I can't seem to figure out how. Is it not possible? I'm doing this to try and use YCBCR instead of RGB, because 1440p @ 120hz will only do RGB when added normally in CRU. Am I attempting to do something that simply can't be done, or am I doing something incorrectly? Thank you.
2560x1440 is not in the CTA standard that defines TV resolutions, and there isn't a way to define YCbCr resolutions currently.
05-15-2021, 03:02 AM
Post: #5836
Everytime I restart my pc, cru settings doesnt apply automatically. I always need to open restart64 everytime, why is it like that? I have latest nvidia 466.27 drivers.
05-16-2021, 05:34 PM
Post: #5837
(05-15-2021 03:02 AM)choichoi10 Wrote:  Everytime I restart my pc, cru settings doesnt apply automatically. I always need to open restart64 everytime, why is it like that? I have latest nvidia 466.27 drivers.
Ask NVIDIA. That's a driver issue.
05-16-2021, 10:54 PM
Post: #5838
I'm using an AW2521H. 360hz, G-sync monitor. I've done the Display 2.0 and 1.3 extension block and added my native and desired reso to them both, neither worked. I get the red text every time. Really want to get this working but i'm not sure what to do the only other guy in this thread who had this monitor stopped responding. Any ideas?
05-17-2021, 02:06 AM
Post: #5839
Hello there, I seem to have bit off more than I can chew.
Ever since I started tinkering with CRU, my display is super zoomed in, and I tried resetting all/deleting my monitor from the list/resetting gpu(ctrl+whatever+b for amd) and uninstalling/reinstalling my basic windows monitor driver. I'm using an hdmi.
A few years ago I had a similar issue and I can't remember how I fixed it, but I am at a complete loss on how to completely reset CRU/My monitor to default. I know it has something to do with unplugging my hdmi or something, but if anyone knows please let me know.
05-17-2021, 02:25 AM
Post: #5840
(05-17-2021 02:06 AM)Austintatious33 Wrote:  Ever since I started tinkering with CRU, my display is super zoomed in, and I tried resetting all/deleting my monitor from the list/resetting gpu(ctrl+whatever+b for amd) and uninstalling/reinstalling my basic windows monitor driver. I'm using an hdmi.
What do you mean by super zoomed in?
User(s) browsing this thread: 153 Guest(s)
